MR2s been sitting, won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2011, 04:48 PM   #1 (permalink)
View TooFast's Photo Gallery
I have 3 MR2s, 89SC and 2 x 91 Turbos that sat for almost 2 years. I used to start them but neglected to lately...all 3 crank good, gas gauges worked but engines don't fire. Now the gas gauges don't work and I can't hear the fuel pumps run when jumping B+ to FP although I do draw a small arc on the Turbos. Haven't jumped the SC car yet. All cars have fresh fuel now.
Anyone see this before?
It's hard for me to imagine all 3 pumps could stick/fail
What's the fix?
TooFast is offline   Reply With Quote
Old 01-27-2011, 12:26 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
if the cars sat for a long time without fresh fuel or being ran, condensation could have built up and caused water to build up in the tank. It is possible the fuel pumps are frozen from the cold.
Although having two cars do it is quite odd indeed tho. I wish i could offer more advice.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 01-27-2011, 09:33 AM   #3 (permalink)
It's all three cars and Denver has a very dry climate, temps were in the 60's...a bit high for freezing.
I'm making up a fuel pressure gauge and double checking all fuses.
Went by the local Toy dealership and this one stumped their MR2 expert.
Once the 89SC (HKS car) and one of the 91 Turbo cars is running, I'm selling them in case someone is interested. Located in Denver, Colorado
Old 01-29-2011, 12:55 AM   #4 (permalink)
Russell D's Avatar
View Russell D's Photo Gallery
Before you go through the work of installing a fuel pressure gauge I'd spray either ehter or get a bottle with a sprayer and spray gas in the throttle bady while someone cranks the car. If the cars start or "pop" when you do that it's a fuel issue, if not it's a spark/wiring issue
-91 Mr2Turbo-363WHP/289WTQ
I'm not happy, More power coming...
Now 386hp/300tq and still not happy
-94 Toyota Pickup SR5-
Russell D is offline   Reply With Quote
Old 02-08-2011, 11:32 PM   #5 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
Hey I just bought a mkII today and have the same problem. My buddy told me it has been sittin out and I just replaced the battery. I tried that method above and it still wont turn over. I dont know if it's the cold weather that's causing it
If you aint rubbin you aint dubbin' (volkswagen)
RU2CHKN is offline   Reply With Quote
Old 02-11-2011, 06:06 PM   #6 (permalink)
Russell D's Avatar
"turning over is a term that can have a few meaning's. Turning over is when the motor is cranking but not firing; If the motor is not turning over that means it's not cranking at all.
When you turn the key does the motor crank?
If so does it "pop" like it wants to start but just wont?
If it cranks but doesn't pop and you've tried spraying gas/ether(starting fluid) into the throttle body and it doesn't pop it's probably an ignition issue. Pull a spark plug out and connect the wire to it and rest the threaded part of the plug on a good groung, then have someone crank the car and watch for a spark on the plug.
Try that and let me know the results, then we can go from there
Old 02-11-2011, 06:36 PM   #7 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Ive tried the ether method and it still didnt start, I havent tried the spark test yet. ive noticed some electrolyte build up on the positive terminal. The terminal is also trashed so ill jump on that and see if thats the problem
Old 02-13-2011, 03:07 PM   #8 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Well I finally got my car started, the positive terminal had a small crack in it plus there was corossion. I also replaced the spark plugs as well, it fires right up now
Old 02-13-2011, 10:08 PM   #9 (permalink)
Russell D's Avatar
Good to hear!
Now let the mods begin
