Supra Brakes on an MR2??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2004, 01:48 AM   #1 (permalink)
View jdmsw20's Photo Gallery
Lightbulb Supra Brakes on an MR2???
I was wondering if anyone knew if Supra brake calipers would fit on an SW20 mr2, and if so what work would have to be done to do so......cause i know that for most Nissan applications you can swap the larger 300zx calipers and they will work, and I didnt know if that would be the case here as well. Thanks
dont be scared of too much power, be worried about loosing without it!
jdmsw20 is offline   Reply With Quote
Old 04-30-2004, 07:00 AM   #2 (permalink)
View SW20 MR2's Photo Gallery
You can use the calipers if you buy the Phoenix Power adapter kit, but it's really expensive. Most kits will use the OEM Supra rotors with Wilwood calipers. Pics of it are on my site.
1991 MR2 Turbo
1996 Civic HB
SW20 MR2 is offline   Reply With Quote
Old 04-30-2004, 07:37 AM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
then u'll need 17'' rims for the calipers to clear....
why are u looking into this swap??...simply for the bling factor??..for the avg driver....a better n cheaper option would be to upgrade to 93 brakes....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-30-2004, 01:08 PM   #4 (permalink)
what makes the 93 brakes that much better? and no not for the bling factor cause I really dispise anything extraordinarily flashy on my car. thanks for the info guys
Old 04-30-2004, 02:25 PM   #5 (permalink)
^^93 brakes are have bigger rotors and calipers....if u do the swap...u will have to use 15" rims min...stock 91 rims will not clear the calipers..
91 mr2..07 335i..
