I don't know if anybody posted pics of this install but i'll post pics of my install. Please excuse the camera work, not my best but it'll do so here ya go:
Stock H4 headlight
Remove 2 phillip screws on both sides of the black panel
Here's the black panel bracket
Next remove the 4 screws from the silver bracket, you don't to remove all of them if you don't want to. You can just remove the top screws and the headlight should come out:
From there you can disconnect the headlight
Comparision of both stock and pegasus headlight
Install H7 hid bulb into pegasus housing
Now I had a spare H4 kit that came with a high-beam bulb but since the pegasus headlight didn't have a high beam just cut off those wires and splice them into the halo wires
This is the part where some members (including me) got confused. Once I hooked up the ballast and hooked up the headlight connector it wouldn't work
So what I did was reverse the polarity of the wires and stuck the black wire through the top socket and reversed the polarity for both red wires until the hid/halo came on.
Next step was to mount the ballast, luckily I had some handy 3M adhesive lying around and used it, I also cleaned the mating surface for the ballast to make sure it stayed on good.
Ta-da ballast mounted!
After all that jazz I connected the hid connectors and installed the pegasus headlight with the silver bracket back on and back bezel panel then voila!
Install is the same for passenger side as well, here's a cutoff pic
I couldn't do a good cut-off test because the car is on jack stands (replacing clutch line)
Well that was my write-up of how to install pegasus projectors, hope it helps other mr2 owners as well
