manual boost controller - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2004, 07:51 AM   #1 (permalink)
View mr2trd's Photo Gallery
would anyone recommend using a manual boost controller? a friend of mine offer to make one for me, but i'm a little hesitant because im not sure if it's safe or not. besides, i don't wont to be boosting over 14psi (i think stock boost is rated at 11psi). would 3psi difference make a significant change? would that be clost to another 15-20hp?
mr2trd is offline   Reply With Quote
Old 05-07-2004, 08:47 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
unless u want to spend over 500usd for an electronic boost controller...then u have no choice but to go with an manual one if u want to run higher boost....u will need to get a fuel cut defender if u want to run higher than 12 psi...the ct-26 should boost up to 16psi max....but it'll be wise to invest an upgraded IC if u want to run higher boost......
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 05-07-2004, 09:53 AM   #3 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I thought stock psi was like 7 - 8?
Old 05-07-2004, 01:16 PM   #4 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
Dudes don't forget to tell the noobie to buy a damn boost gauge! And also much after 17 psi the CT-26 will hit 'thermal efficiency.'
Brandon
arcasmachineracing is offline   Reply With Quote
