Originally Posted by rtknighton
The hg is a must. I drained my coolent and there is oil in it. So no madder what I need to do that. Timing belt is preventative maintenance but I might as well do the rest. New water pump the works. I'm thinking about 400whp so if I deside to build it up I will stick with the second gen. What about bpv vs bov I have been reading alot and people are saying the stock bpv is the best way to go and most reliable. Dont get me wrong I love the sound of an aftermarket bov but it's not a must for me? The turbo on my car isn't stock and I don't know much about it however it does work very well. T3. I have been told if I am going to build my second gen I need to get a standalone computer system to support it. Which would eliminate the need for 12psi cap, afm, and recirculating bov? I don't know alot about this though is it a must?
Stock BPV is the best and most reliable. It uses a diaphram instead of being spring loaded like the aftermarket BOV's. They eventually fail, can cause rough idleing and you get a " rich fuel mix" everytime you shift gears.
The BPV is much more responsive too.
If you're running a T3/T4 turbo, you should really use some type of engine management to take advantage of the turbo- with the neccessary fuel upgrades of course.
I would rebuild, but know that you will not achieve 400rwhp with the T3.
You'll need a bigger turbo than that.
