Fuel pump power issue 86 MR2
So, 86 NA 1.6 Mr2 has been sitting a while, started every now and then but probably not enough. ill cut straight to the problem. Fuel pump will not run after startup. at keyon it will cycle and turn off, obviously it has power and works. jumpered out the fuel pump on the diag port and the car runs fine. replaced the MAF with one from a 22r I had laying around (oddly enough the same MAF) still same issue, replaced the relay with same relay from same 22r truck. still no go. held the flap open on original MAF and it still would not power the fuel pump. is there something I'm missing that could cause this? I cant find where the pump gets power from while the engine is running so I cant trace the wire back and check voltage. about to just wire the pump to a switch on the dash at this point.
Thanks for any info.
