250hp NA? you are just past Formula Atlantic range there. 1.6L 240hp @ 11,000rpm.
the 1zzfe is not a powerhouse of an engine. think of it this way, every corolla from 2000+ you see, has that exact engine.
i'm not trying to shatter your dreams. i'm trying to demonstrate that getting a gob of power from that engine would be... difficult and probably VERY expensive.
if you just want to give it a bit more kick, then its the usual intake/exhaust formula. going a bit further, its a matter of how deep your pocket book is.
but, if power is your ultimate goal, than a small turbo would be the most effective method of getting to that power level. then its just a matter of making sure you can supply enough fuel and have a good ECU/StandAlone to make sure that it doesn't grenade the first time you hit redline.
