What is your budget for cams? If you want to try something basically for close to free, you could run a small port exhaust cam to broaden your torque band a bit. Have you looked at Kamakazee Cams?
http://tedcomponents.com/4ag.htm How about the good ol' 101 grind webcams?
http://www.webcamshafts.com/pages/au...75_000698.html
If you are gonna get a good flowing cam, then you'd want to get an exhaust system that can keep up with it. What header options have you been looking at?
I
HIGHLY recommend giving Billzilla's website a good read to learn how to extract power outta the 4A:
http://www.billzilla.org/4agmods.htm
Other things that come to mind are...
What flywheel are you running?
You can easily turn stock cam gears into adjustable gears in less than 10 mins with a dremel and adjust your cam timing to maximize power in the particular band you are looking for (lower, mid range, upper).
You can enrich your fuel mixture by playing with the AFM. See my guide here:
http://board.marlincrawler.com/index...50504#msg50504
You can disconnect the vacuum source to your EGR valve
If you live in a climate that rarely sees freezing temps, you can install a $5 brass water valve in your throttle body heater circuit to shut the flow down to about 10% or so (or just disconnect the water all together if you don't mind having a cold idle all the time = free).
What sort of air cleaner are you using? If its an open element in your engine compartment, then you could duct some cool air to your air filter for cheap.
You could run some Denso Iridium plugs, also get some Nology Hotcore Wires...
Also, have you considered the inverse of lightening your car? Remember acceleration = force divided by mass, so less mass will result in higher acceleration. If you wanna get serious, you could easily loose 80 lbs of just carpeting, sound deadening, and unneeded plastic panels. Remove your A/C system (if you have one) and both bumper cores for another 100 lbs removed, etcetera... How about light weight wheels?
Again, it's all about how serious you want to get.
BigMike
