MKIV supra IC in MR2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2004, 08:26 AM   #1 (permalink)
View mr2trd's Photo Gallery
I just wanted to know if the fabrication needed to put an MKIV supra TT IC in the MR2 would be difficult? I did see it done on one car...i think on cardomain and it looked sweet. i'm assuming that the Supra IC upgrade will be similar to the GReddy in performance, but will cost significantly less. The IC is 10.75x9x5, im not sure about the dimensions of the GReddy though.
mr2trd is offline   Reply With Quote
Old 05-14-2004, 08:39 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
u would prolly have to weld new end tanks to make it work....and then some custom IC piping and the cost of the IC.....add that all up...and u prolly won't be far off from the price of a new greddy or apex-i unit.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 05-14-2004, 12:03 PM   #3 (permalink)
Gameroom cash: $134355
the best ic mod in an mr2 i've seen is in "the beast".... they put a big "front mount" facing downward into a hole they cut in the trunk, then faced 2 t-fal fans firing downward into it..... and also has a rear facing hood scoop to allow air flow through it
