Originally Posted by not12listen
as a point of reference, i am putting a 3sge into my AW11. i have done what i think is reasonable to my swap, others will disagree. i have dropped over $6000 into it, and i'm still not done. i do believe i even did a price breakdown too.
none of that takes into account what it will cost you to have the original left and right engine mounts CUT OUT of the chassis of your AW11.
and again, UNLESS you start with an SC AW11, then you will NEED to swap over the hubs, as the NA hubs will NOT fit the turbo axles splines. that boils down to MORE MONEY. how much depends on where you get the hubs and what kind of deal you find.
whoah dude, calm down.
#1.... SC and n/a hubs have identical placement and outer splines. There is a variance in the rear suspension in which the hubs are different -- but that has nothing to do with axles.
#2.... the cost will all depend on his, and friends who help, ability to weld, wire, and fabricate. Further it will also depend on who what he pays for the motor/trans
#3.... as I said in your post I'm gearing up for a 5sfe swap. Though not a 3sgte (this is a much easier swap) I am looking into a couple options on how to install. One way, which was done successfully on a v6 aw11, apparently, is to create brackets between the stock mount and the new engine mount. I will be looking into this option as it may not require any cutting of the chasis.
For my 5sfe/s54 SW20 swap into the aw11 I'll be looking to have less than $800 total... including engine, transmission, wiring, axles, hoses, etc. Your $6,000 price tag is because of how meticulous you are and that many of the items you're using are quite expensive.
$450 for a full 91 motor/trans out of an SW20 (picking up today)
$85 for ecu, sw20 wiring harness, and sw20 coolant filler neck
Expecting to spend around $50-100 at a pull-a-part to get the intake side alternator/bracket and maybe some various mounts to see what I can make work.
$100 on an ebay 5sfe header... unless I can find a 3sfe rav4 in the yard...... however if the motor comes with a good cat I'll get another $40-50 returned just by taking it to the scrap yard.... probably paying for any metal I might pick up.
The speed source mounts are extremely useful. Don't get me wrong. However I cannot fathom spending that kind of money on about $30 of scrap metal and a couple hours of welding. The jig isn't necessary if you know how to use a tape measure. Those are definitely useful tools but I don't feel they're required.
other than potential future "costs" if you decide to not have an mk1.5.... cutting the stock mounts out of the side would cost about $5 in blades and 20 min or so to get 'em out.
