My 4AGE Silvertop swap into my AW11 so far and info - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2011, 10:37 PM   #1 (permalink)
View tidus21's Photo Gallery
So I am having my AW11 swaped in with a 4AGE Silvertop engine. As of right now the Engine is in, and all the major wiring is done. We have gotten the engine to turn over and run for a short 30 seconds. There have been many issues along the way however many I thought I would post here just in case anyone else was looking at a Silvertop swap. I bought this car for about 500 with a bad engine...and well bad everything really.
Exhaust manifold/header: Before attempting the swap make sure the exhaust is in good condition because more than likely you want to use your original set up and not the one that comes with the engine. This is because the starter will have to be moved to the front and the stock manifold of a Silvertop does not give enough clearance for it. The stock 4AGE will, but if you run into the situation that I did, many times if the car is not taken care of the manifold will be cracked in several places making it unusable, luckily I found manifolds online that are rebuilt for the 4AGE.
Wiring:Now that I know, I would recommend going with a Megasquirt system instead of a stock ECU for Silvertop. One reason that I have found out is that many of the JDM import companies do not guarantee that your ecu will come with all the neccissary plugs and pigtails like mine which did not have the 12 plug pin. If you do go with the stock ecu(dumb part on me that I didnt think of it earlier) open the case to see the what wires to where...makes things alot easier. Lastly you wont know what condition your ecu is in, mine was probably soaked at one time by coolant making it no good for the swap(started to smoke, when we fired up the engine).
Other things:Be aware that with this process, the clutch should be replaced, you have new custom hosing for the coolant lines, your throttle line will need to be changed.
Cost:Look around and talk to different shop around your area and ask if you can see some of their other work. I went into the shop I finally took it to and looked at their work and saw the car's they had in the shop. Make sure to get updated quotes as the swap goes on. I was quoted at 1200 for the swap and so far my cost has run me about 1500 without the megasquirt system in. So a grand total of around $2000 for a complete swap compared to others that quoted me between 3k-4k
I am still doing some finishing touches and it will be ready within the coming weeks.
tidus21 is offline   Reply With Quote
Old 07-02-2011, 08:00 AM   #2 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Looks good!
Theres a guy (mr220v) on mr2oc that makes plug and play harnesses for the AW11 20v swap. WAY easier than trying to figure it out yourself!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 07-02-2011, 04:42 PM   #3 (permalink)
Marlin Crawler, Inc.
MC_BigMike's Avatar
View MC_BigMike's Photo Gallery
That is awesome. Someday I'll build a 20-valve AW11! If you have more pics, please share!
BigMike
My Supercharged 6-speed 1987 MR2: http://bigmike.marlincrawler.com
My 511:1 3RZ-FE powered 1981 Hilux: http://board.marlincrawler.com/index.php?topic=4401.0
MC_BigMike is offline   Reply With Quote
Old 07-04-2011, 11:39 PM   #4 (permalink)
Originally Posted by aaron7 View Post
Looks good!
Yeah I actually looked into it but it was out of my price range for what I was already doing. The wiring is set and ready for the new harness that is coming with me MSII. Luckily all my wiring work is being done by a mechanic so I am pretty safe there.
I made sure before hand to look and do my research to make an adequate budget size and I was determined to not exceed it. My overall budget for the entire swap is $3500(include cost of engine and parts) and I am right at 3200 so I am going to invest in an aftermarket intake, new exhaust, and a new dashboard since the gas gauge failed and no longer works.
Old 07-04-2011, 11:41 PM   #5 (permalink)
BigMike
I will and I will post a video up as well to show the new engine and how it runs. That picture was taken a while ago before the coolant hoses were set up without the header and a the harness was not complete. Everything is set and ready to go in the car except for the new MS II ecu that is going in and the wiring harness for it. Afterwards it will be ready...hopefully by this weekend.
Old 07-05-2011, 12:01 PM   #6 (permalink)
MC_BigMike's Avatar
Noice!
