swap engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2011, 11:19 PM   #1 (permalink)
View jaeciphmr2's Photo Gallery
swap engine
i have a question. i have 91 mr2 turbo and i bought a 94 mr2 turbo engine..Is there any customise need to be done or it will just fit easy?
jaeciphmr2 is offline   Reply With Quote
Old 06-30-2011, 12:43 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I believe it's plug and play. I would definitely use the 94 ECU.
The Jedi Speeder at CarDomain
The Following User Says Thank You to MR2Jedi For This Useful Post:
jaeciphmr2 (06-30-2011)
Old 06-30-2011, 10:43 AM   #3 (permalink)
ok..have question..about the axle..they said i have buy after market axle that would fit from 94engine to 91 chasis mr2.. or ill jus buy an axle for 94engine and it will fit perfectly without spending much money?
Old 06-30-2011, 10:59 AM   #4 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
i have a gen3 transmission and gen3 axles in my 91 mr2 without any extra type of fitting. Direct swap.
TheEngineer is offline   Reply With Quote
The Following User Says Thank You to TheEngineer For This Useful Post:
Old 07-01-2011, 12:25 AM   #5 (permalink)
andyb16's Avatar
View andyb16's Photo Gallery
Just to make sure, since your wording is kind of unclear...
If you're re-using your transmission your axles will still work. If you got a transmission with the new motor and it has LSD, your 91 axles won't work without some modification, since LSD wasn't available in '91.
Also, is the '94 motor from a u.s. model, or is it japanese? If it's usdm, then like the other guys said, it will be pretty much plug and play. If it's JDM, that's another story.
andyb16 is offline   Reply With Quote
The Following User Says Thank You to andyb16 For This Useful Post:
jaeciphmr2 (07-05-2011)
Old 07-01-2011, 12:34 AM   #6 (permalink)
andyb16's Avatar
Just saw in your other thread that you have a non-turbo motor in a turbo chassis? If that's the case then the swap is a bit more involved. You'll need the turbo ecu, wiring harness, intercooler and piping (dont know if that's included with your new motor) and I'm not sure if the non-turbo transmission will work. I think it will, but I don't know for sure.
Old 07-03-2011, 03:25 AM   #7 (permalink)
mr2oogleX
View moogleX's Photo Gallery
my swap from 5s-fe to 3s-gte I needed new fuel pump as well as the engine/tranny/intercooler/ecu/wiring harness
for the axels, you will need new wheel hubs as well for the new transmission. If Chico Race Works still sells them, he makes axels that will fit the turbo tranny, and are machined to fit the 5s-fe hubs.
my swap thread is floating around here somewhere. did it about three years ago.
EDIT: Just noticed he already had a turbo model MR2, so this info kinda useless.
Originally Posted by Quandry
...Turbo's have vaccum too, it's just not the fun part of the gauge
moogleX is offline   Reply With Quote
The Following User Says Thank You to moogleX For This Useful Post:
Old 07-05-2011, 03:01 PM   #8 (permalink)
andyb16:thats a good point. i bought my engine at tigerjapaness company..i have to find out if its made here in US or japan...engine comes with trans...so.. i guess i have to buy a 94 axles since my engine is 94..hope everything will fit perfectly..
Old 07-05-2011, 09:20 PM   #9 (permalink)
andyb16's Avatar
The year isn't important as far as the axles go. What's important is if the trans is LSD or not. Non-lsd axles are all the same no matter what year. Same as lsd axles, the year doesn't matter. Non-lsd axles can be machined to work in an lsd trans. But like I said earlier, if you're re-using your current turbo trans, just use your axles too.
A ay to tell if it's JDM or not is to look for an EGR valve. It's a little round valve next to the intake manifold that has a pipe going into the head next to the valve cover. USDM motors have them, JDM do not. I think that if it's a jdm 94 motor, it's a 3rd gen (nice improvement over the usdm motors). Pretty sure 94 is when Japan got the good stuff, we got stuck with the 2nd gen through 95 over here.
