1991 Turbo MR2 (3SGTE, Swapped, 95% stock)
The Story:
Just picked this car up a week ago. Previous owner was supposed to meet me at our predetermined meeting spot. I planned on trailering the car home and had already driven the 2 hours to get to the meeting spot. I get a phone call from the previous owner, the car is bogging really bad and is acting up and he is working on trying to figure it out(Go figure, was perfectly fine until now). He had JUST filled it all the way up with gas and was on his way when it started doing this, suddenly. I find this hard to believe because the car is undrivable in its current condition. He changed the spark plugs and oil. Gave me money for a new fuel filter, spark plug wires and an o2 sensor, thinking 1 or all of these things could be an issue.(Also got 4 brand new tires in the deal) I took the car since I was already down there and went on my way. Nice MR2, needs a better paint job, but rust free and very clean.
The Problem:
Car idle's like COMPLETE s*** and will not go above 800rpm~ even at WOT.
Here is a video I took of what the car is doing. Take note of the boost gauge and vacuum as well as RPM's. The video makes the knocking sound a lot louder then it really is.
Moving forward.
The CEL was on, so I did the paperclip trick and got the codes from the car. Here is what I got:
22 - Throttle Position Sensor (Did OHM check, tests fine)
24 - Vehicle Speed Sensor (Speedometer doesn't work)
31 - Gear Position Switch (Shift linkage is messed up)
34 - MAP Sensor Curcuit Error (???)
35- IAC Problem or Idle Error (No S*** lol, ???)
I can already rule out codes 22, 24 and 31. 34 and 35 are my big concerns right now. I'm trying to check to see if my IAC is dirty or faulty, but I'm having issues getting the damn thing off so that will have to wait.
When I went to pull the codes, I had a hard time finding the diagnostics port for the car because it was not where it was supposed to be. Instead I found it free-hanging between the intake manifold and the trunk wall. Also, there was a plug unplugged which I later found out was the MAP sensor plug.. I still cannot find out where it plugs into and I've looked just about everywhere it should be. Now I know the car is swapped, but I'm not sure what gen wiring harness was used or any of that.
So I wonder if the MAP has always been unplugged, or if the plug fell out leaving the sensor on the road somewhere(someone not bolting it up or plugging it in tight)?? This is my most main concern right now. Where the MAP goes and IF I need it or not, I'm assuming I do. Should I buy a new map sensor and plug it all back up?
I'm clueless right now as to what is wrong with the car. Could it be something totally different or is the unplugged MAP sensor wreaking havoc on everything? Or could it be something way off the beaten path messing everything up? Here are a few things that have been suggested to me or possibilities I thought up:
Timing? (Some say yes, some say no)
Bad gas?
Wrong gas; 87 instead of 93 on accident (Previous Owner accident?)
Stuck Injector?
Bad Fuel Filter?
Spark Plug Wires?
o2 Sensor?
Tiny Unicorns poking holes in hoses and sh**ing in filters? (Dane Cook lol)
I'm always online and can provide any more information if need be, quickly.. I've got my concern posted on a few forums right now and have gotten several answers, but things have slowed up and or been ruled out.. I want this fixed ASAP!
Any and all suggestions would be greatly appreciated.
