no.
at least in stock form the AW11's main wiring harness is horrible (I don't care who disagrees with me... it is). There's 2 main cables that come off of the harness... 1 for the starter and 1 for everything else in the car (all accessories power, engine power, and alternator charging).... there's 1 fusible link that runs on this wire that's about 5" long or so... then from there it gauges up to a 6 ga cable.... 10" further down or so 2 more 6 ga cables split off of it to run to the cab. The main cable runs to the alternator... within 10" or so of it one of the 3 wires from the alt plug splits off of this main 6ga cable as well.
It's a horrible design that lends itself to really bad corrosion.....
Now the really bad news..... if yours is corodded.... this runs through the main EFI harness.... in order to replace it requires pulling the entire harness apart between the alternator and the battery (and the 2 grey connectors on the drivers-side strut tower).
Before I did the Mk1.22 I rebuilt most of the engine harness because of this issue... here are just a couple snap shots.... my fix (when it was still in the car) before rebuilding the harness was to cut the end off the alt connection, leave it connected to the battery, then run a new 6ga cable straight from the battery to the alternator.
