91 MR2 Non Turbo idles too high
I've got a 91 MR2 non turbo that won't pass smog because it idles too high. It idles at 1100 rpm warm and it's susposed to be down at 750 rpm according to the test center. The idle adjustment screw is turned all the way down. All the hoses have been replaced. New plugs, cap, rotor, and wires. Tried another throttle body, no help. Switched ECU's, no help. Timing is 10 TDC. Tried a new Air Idle Control Valve, same thing. The car runs great, and passes everything else just fine except it simply idles 300 rpm too high. Cleaned up the EGR valve and everything else I could get my hands on. What else can I do? I'm thinking about replacing the timing belt next. Any ideas? Please help. Thanks
