I thought 1zz comes with shim under bucket lifters?! What i have done so far is to have all shims measured while the head is still with stock cams. Clearance is 0,25 if i am not mistaken (not sure how much should it be with the new cams though)Then i have taken the sizes of all the shims as follows-4x2.80 ,4x2.85 ,5x2.90 ,2x2.95 and 1x3.0 .
If i remember correctly 1zz is shim under bucket and 1sz is shimless.The second one is found in Yaris and for 1zz i am not sure which model has that one.
Isn't it better if i just get shim under bucket lifters from 3 Gen 3 SGE ???
I will have to decide today or tommo cos' the cams (brain crawler ) will be shipped on Tuesday from USA.
Could you please help me with that?
Thanks a lot
PS: could you pls have a look
www.toyodiy.com
There are all diagrams of all Toyota models. I am getting confused by the sizes there in the order specs cos' they start from 5.06 ???
Do you think these sizes come including the size of the lifter its self.
I just checked 1zz and you are right of course
