Hi everyone
Could any one help me with an advice?
I've got new Brain Crawers cams 272* with springs and retainers kit for my MR2 3SGE engine.Everything will be in place these days (including adj. cam gears) and i am planing to use Map Pro Scan to adjust the ignition and fuel. Can you pls tell me your opinion and if you could tell me also how to rise the RPM limiter ( not sure if it is possible with electronic like that)? It is not stand alone (for now
and i hope that we will be able to do all the set ups. Can you recommend me some software for adjusting the limiter or if i could directly play with the stock ECU?
Thanks a lot and all the best
