i have two 10 inch audiobahn flame subs in seperate boxes behind each seat power by a bp300.1 amp...an this shiiii SLAMMMMS! However i simply ran the wire through the side of the door where it closes and slipped it in a tiny gap when door is open and led directly under front hood to BATTERY! Then i just tucked the wire under the door sills and everything is great!!! Also the door doesnt cut or harm the power cable at all even when door is shut...it doesnt affect the wire in the least bit nor does it stop you form closing your door! Also i used 4gauge wire...THICK!
-Won Eye-
TRJ
"You gotta learn ta crawl before you can walk, and driving 160MPH straight is a walk in the park comapred to driving 90MPH sideways towards a wall!"
GARY CASTILLO
