Lightened pistons for mah camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2011, 07:51 PM   #1 (permalink)
Location: Houston, Texas, USA, North America, Northern Hemisphere, Earth, Galaxy, Universe, Vergo Supercluster
View oscaryu1's Photo Gallery
There was some more machining done all around... they sit at 369.1 grams right now... a far cry from the stock 400-410g. Only time will tell if they blow LOL.
oscaryu1 is offline   Reply With Quote
Old 11-06-2011, 10:27 PM   #2 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
well first ill ask.....why? and second i hope you didnt ruin the structural integrity of the pistons because the ammount of pressure and heat then undergo may very well ruin the engine if they fail
TheEngineer is offline   Reply With Quote
Old 11-06-2011, 10:57 PM   #3 (permalink)
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Gameroom cash: $618331
View Zembonez's Photo Gallery
I would never remove material from the combustion surface structure... What can possibly hope to be gained here with "somewhat lighter" pistons? Is this a boost motor or some kind of stroke build?
Zembonez is offline   Reply With Quote
Old 11-07-2011, 01:07 AM   #4 (permalink)
Boosted motor.
Less rotating mass. Means I can significantly cut down on the amount of counterweights I need on the crank. With an inline 4, primary imbalance isn't an issue but secondary is. Relieve my issues with chucking the crank in a lathe and knifedging it by lessening the rotating mass, the reason for the counterweights in the first place.
Don't worry, I didn't just chuck the pistons in a mill and hope for the best. I measured out the valve reliefs and left enough aluminum in the crown to take the brunt of everything.
These pistons are overbuilt anyways. They're nearly .4" crown thickness to begin with... unnecessary and overbuilt, but in a good way. It'll be getting oil cooling and ceramic coatings to help it cope.
Old 11-07-2011, 09:00 AM   #5 (permalink)
Zembonez's Avatar
Sounds like a plan!
I was hoping this was not some random "I think I'll lighten my pistons" episode.
Old 11-29-2011, 07:16 AM   #6 (permalink)
View pbr333's Photo Gallery
rev it up
nice! oscaryu1 less weight on that rotating assy means it can rotate
faster...more quickly..
do you plan on lightening the crank counter wieghts or will that be done in the knifedging process? I need to do more studying on the bottom end balance thing ....but I'm in the middle of a build now. I'd be scared to grind on these new forged pistons and rods, that I payed and arm and a leg for! However , I am looking for an economic solution for the lightened flywheel.
Looking at cheaper chrome molly flywheels now.
pbr333
pbr333 is offline   Reply With Quote
