91 MR2 Non turbo Ground Strap locations - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2011, 05:02 PM   #1 (permalink)
View Dschloe's Photo Gallery
Hi New to the site so I hope I'm posting in the right location. Could someone please help.
I'm doing a motor swap and its been a project that I've only been able to work on the weekends for a few hours at a time so in this process I forgot where the ground straps go could some one please send pictures or let me know please. I was able to crank the motor over but I must have had it grounded wrong and it burnt the one ground strap that I had on it at the time. If I try with out the ground strap the fuel pump starts as soon as I connect the battery.
Thank you in advance.
Dschloe is offline   Reply With Quote
Old 12-28-2011, 07:24 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
What motor are you swapping in? 5sfe or 3sgte?
The Jedi Speeder at CarDomain
Old 12-28-2011, 08:11 PM   #3 (permalink)
its another stock 5sfe. My son blew the original motor so were swapping with another stock motor.
Old 12-29-2011, 04:20 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Well, I looked in my manual and couldn't find anything.
I can tell you on the 3sgte, there is a ground on the manual transmission to chassis. A ground on the head to body. And a ground on the block to chassis.
I think if you do the same, you should be good.
Old 12-31-2011, 07:12 AM   #5 (permalink)
Thanks I did that and it appears to have fixed the problem. I was able to get the car start but I have no throttle response. I can manually work the throttle but nothing seems to happen. Any thoughts?
Old 12-31-2011, 08:30 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Is the AFM hooked up? Throttle Position sensor?
Old 12-31-2011, 09:28 PM   #7 (permalink)
Yes they are both hooked up. I was thinking it was the tps. How would you test it?
Thanks
Old 01-01-2012, 01:31 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
You have to remove it.
You'll need and Multimeter and feeler gauge. I'm at work right now(yeah, New Years Eve), but I will post the specs later if no one else has before then.
Old 01-02-2012, 10:12 AM   #9 (permalink)
Thanks I'm going to take a look at it today and see what I can find out. I did buy a new one in case this one is bad. But if you do run across the specs that would be great.
