speed?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2004, 05:26 PM   #1 (permalink)
View si_mr2's Photo Gallery
speed??
Hi, i have a 94 mk2, generation 2, automatic ,import MR2 and i was just wondering what the top speed will be as the speedo only says 100mph due to it been an import.
Thanks Si
si_mr2 is offline   Reply With Quote
Old 06-05-2004, 07:45 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I took mine about 130mph in the desert by willlow springs when it was NA. I don't think the top speed gets too much faster w/ the turbo.
Old 06-06-2004, 06:30 AM   #3 (permalink)
was yours a n/a?
Old 06-06-2004, 08:48 AM   #4 (permalink)
Gameroom cash: $253010
iTrader Score: 6 reviews
View BDSL's Photo Gallery
For turbo genII, top speed is somewhere between 145mph to 150mph.
I have gone to 140mph myself.
BDSL is offline   Reply With Quote
Old 06-06-2004, 08:51 AM   #5 (permalink)
So does the speed differ between the automatic and manual version?
Old 06-06-2004, 11:10 AM   #6 (permalink)
Piddy's Avatar
I dont' think the top speed really differs between auto/5spd. Yes mine was NA at the time. It's been swapped since then though.
Old 06-10-2004, 08:39 AM   #7 (permalink)
View boricua52385's Photo Gallery
The Jspec tranny will hit 110in 3rd, so if you got the power, I think 160-170 is obtainable
boricua52385 is offline   Reply With Quote
Old 06-10-2004, 10:15 AM   #8 (permalink)
View drunknfuctup's Photo Gallery
Boricua - What are the gear ratios for the US spec and the JDM? Is the difference in the gearbox or the rearend? More info please......
drunknfuctup is offline   Reply With Quote
Old 06-10-2004, 10:20 AM   #9 (permalink)
So could you roughly tell me my top end speed on an *automatic*? Thanks Si
Old 06-10-2004, 10:30 AM   #10 (permalink)
Piddy's Avatar
Where did you hear that?
Stock max speed is around 130mph.
Old 06-10-2004, 01:21 PM   #11 (permalink)
I'm not sure about specifics, but I'm guessing its just wider gear ratios than the US spec. The only thing I'm sure about is that it has the same bolt pattern as the 5sfe, it bolts on no problem. I'd never get it though, I have no reason to go above 140mph
Old 06-10-2004, 01:27 PM   #12 (permalink)
a close friend's cousin has a 12 second 5sfe, he recommended I swap the tranny instead of upgrading my clutch. He was complaining about the 5sfe tranny running such high rpm when cruising on the highway. Where he got the info, I don't know... sorry I can't answer that. I couldn't find an actual top speed online, but I know the 4th gen 3SGTE puts out 260-270hp stock
