MR2 Trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2004, 08:52 PM   #1 (permalink)
1993 MR2 Turbo
View josephah2000's Photo Gallery
MR2 Trouble
My 1993 MR2 Turbo is not starting. The battery is dead so I tried to jump it and smoke started coming from the negative terminal and the voltage jumped skyhigh. Also, both positive and negative cables near the battery got very hot.
Any clues????
93T Lightly Modded @ 15 p.s.i.
josephah2000 is offline   Reply With Quote
Old 06-07-2004, 09:12 PM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
If the cables are hot, my best guess is that theres a high chance you got a SHORT in your electrical system. (ie. live wire touching a ground)
ratko.org
Ratko is offline   Reply With Quote
Old 06-10-2004, 08:18 AM   #3 (permalink)
View boricua52385's Photo Gallery
I had a similar problem, but I never tried to jump it. My car would still turn over, but woudn't start, the problem ended up being a lose igntion coil ground wire. If you've done any wiring yourself, check for broken or damaged wires, or a lose ground wire around your engine compartment. I'd recommend using a a voltmeter to check your circuits for continuity, that's probably the easiest way to find a short. Good luck. Don't too frustrated.
boricua52385 is offline   Reply With Quote
Old 06-10-2004, 06:28 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
it's prolly water locked, try removing the spark plugs and spin with them out, we told you the head gasket was blown in your other thread....
http://www.toyotanation.com/forum/sh...694#post367694
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
