distributor problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2004, 08:10 AM   #1 (permalink)
View mr2trd's Photo Gallery
What's up TNers, it's been a long time since I've been on. Anyways, I found that oil was leaking from where the distributor bolted up to the block. The thing is, I couldn't find anything wrong with the distributor that may have caused the leak...the seal is still good. I'm not sure if it needs silicone sealant also.
Secondly, does anyone know how to do 'Timing' ? After taking the distributor off, I'll need to do some timing to get the car up and running again.
Could this leak have affected performance?
Alright, thanks guys. laters
mr2trd is offline   Reply With Quote
Old 06-08-2004, 03:33 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
any oil leak is not good and should be fixed ASAP.....base timing should be 10 degrees....i think u'll need a timing gun to set ur timing...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 06-09-2004, 07:58 AM   #3 (permalink)
how can i use the timing gun, though? i can feel the timing marks on the pulley but i can't see it because another belt is blocking the view.
anyway...i didn't fix the leak...don't know what's wrong with it. i did get a new O-ring for the distributor, but the leak is still there. i'll try again....ARRGGGGHHHHHH!
Has anyone experienced this happening before? if so, give me some advice...
thanks/
Old 06-13-2004, 06:06 PM   #4 (permalink)
is it normal to have some minute amount of oil leak from the distributor into the rotor cap? is the distributor shot or what??? i don't want to spend lots of $$$ to buy a new one.
