Some brake work help on my MR2 MKII... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2004, 06:49 AM   #1 (permalink)
VIP
View SILVERROLLA's Photo Gallery
I need to replace the pads on my MR2. Is it all that hard? I am a first timer doing this stuff and would like to know the level of difficulty of this job. I have most tools to do the job (I think??) Can someone plz tell me what tools I need to use in order to remove the calipher to put the pads on.....
SILVERROLLA is offline   Reply With Quote
Old 06-21-2004, 07:45 AM   #2 (permalink)
Gameroom cash: $253010
iTrader Score: 6 reviews
View BDSL's Photo Gallery
The rear brake piston can only be pushed back in using a special tool. Or you can use a needle nose plier and turn it back in. Be careful not to puncture the gasket. The front brake piston can be pushed back in using a c-clamp.
Remember to lubricate the slide pins.
Make sure you put some anti-squealer on the shims.
Bleed the brake fluid while you are at in.
BDSL is offline   Reply With Quote
Old 06-21-2004, 01:30 PM   #3 (permalink)
VIP
ok thanks for the info. Im getting started on my brakes now. I will also change the rotors
