Timing belt$ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2004, 02:19 PM   #1 (permalink)
GOT A 93CAMRY&92MR2-T?
Zer05's Avatar
View Zer05's Photo Gallery
Question Timing belt$
The only thing I haven't replaced on my 92 mr2 turbo is the timing belt since I brought it from a private owner..How much will it cost me to get it replaced?
05
Zer05 is offline   Reply With Quote
Old 06-22-2004, 02:31 PM   #2 (permalink)
View Dennis's Photo Gallery
timing belt is a costly part to replace. if you can find a good reputable shop locally and not go to the dealer, then you might just save a couple of hundreds of dollars.
Dennis is offline   Reply With Quote
Old 06-22-2004, 02:53 PM   #3 (permalink)
Zer05's Avatar
Thumbs up Thanks for the heads up
I knew it was going to cost an arm n a leg. I'll ask my local shop for pricing.
05
Old 06-22-2004, 02:56 PM   #4 (permalink)
View SandrasUserName's Photo Gallery
If you do the work yourself it will be a lot less.
I get coupons on the mail from Toyota & timing belt "special" are always on there. It's between $150-$200 with the coupon, I have them at home I don't know the exact amount off the top of my head.
88 J-Spec SC MR2
03 V6 Camry
SandrasUserName is offline   Reply With Quote
Old 06-27-2004, 09:12 PM   #5 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
^^^You gotta look at the fine print on those... usually they'll say "MR2 slightly higher"
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 06-30-2004, 12:01 AM   #6 (permalink)
View downtempo's Photo Gallery
Timing Belt Cost
I just had mine changed at Longo (El Monte).
Timing Belt special - $119 (inc. parts & labor).
Not sure if they still have the special, you may want to call.
Don't plan on getting anything else done at the same time though.. it's a loss-leader for them and they are out to get more $$ from you. I asked to get the water pump changed at the same time (part cost ~ $80, labor time ~ 15-30 mins). Should have been a small upcharge .. ~ +$100-$125. They instead wanted to charge me $375!! And that's the cost AFTER I negotiated. They didn't care that I knew the real extent of what they had to do.. they just kept to their story.. "It's a 2-3 hour job."
Good Luck.
downtempo is offline   Reply With Quote
