mk1 failed NO test - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2004, 07:14 PM   #1 (permalink)
View deportes's Photo Gallery
mk1 failed SMOG "NO" test
New to the forum, I hope I can help as well.
The plugs are whiteand supposedly running lean.
Checked the EGR valce and it is in good condition, the Actuator I need to check next.
Any other know culprits that make the car run lean.
Timing is perfect on the yellow mark, new plugs, higher octane gas. What elsa can I do before re-testing it?
thanks, Juan.
deportes is offline   Reply With Quote
Old 07-16-2004, 10:46 AM   #2 (permalink)
View OEMonkey's Photo Gallery
If you failed NOx, most likely the egr passages need cleaning. Testing the egr by applying vacuum to it while idling is not a good way of testing it. All it tells you is that it opens when enough vac is applied. Also check your base ignition timing, check for low fuel pressure, a rich biased o2s, vac leak, etc.
NOx forms when temps are high. High temp is caused by a lean condition.
OEMonkey is offline   Reply With Quote
Old 07-17-2004, 09:29 AM   #3 (permalink)
Thanks OE Mokey, I did remove the EGR when I tested it and all passages are clear as well as the tubing to and from.
The timing is good, 10deg btdc.
How do you check for a rich biased O2s?
I willperform the other checks. I will also test the EGR actuator to see if it works as desired.
thanks, Juan.
Old 07-17-2004, 10:11 AM   #4 (permalink)
Rotor > Piston
powderblue91's Avatar
View powderblue91's Photo Gallery
check your o2 sensor and if your car was built in 91 or later it can be your cat. converter
-Eric
1991 SV21 DX - The slow
1990 FC3S GXL - The go
powderblue91 is offline   Reply With Quote
Old 07-17-2004, 04:12 PM   #5 (permalink)
GOOD NEWS, it passed. Last time the NOx was 1135
max 825. Today it was 822 wow...
Put un new sparks, 91 octane fuel and prayed a lot. 2 more years.
thanks, Juan.
