MR2 Turbo Tranny Question, Please Help!
I just bought a 1991 toyota mr2 turbo that does not go into gears 5th and reverse very well. What it does is, when trying to shift from 4th to 5th it will not go into that gear. It just goes back into 3rd gear when trying. To make it go into 5th, you must put it into nuetral, press the shifter in the direction of 1st gear and then slam it into 5th. Very strange. The gears do not grind and the clutch is recent. Reverse is very touchy, very hard to put it into reverse. It mostly goes into 4th gear when trying. Someone had told me that it could be the shifter mechanism rather than the tranny itself. Any help would be appreciated.
