light chatter at clutch engagement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2004, 11:34 AM   #1 (permalink)
View carcatz's Photo Gallery
Unhappy light chatter at clutch engagement
I just ahd my clutch replaced and have a light chatter occasionally when I down shift or start off??
carcatz is offline   Reply With Quote
Old 09-28-2004, 09:34 PM   #2 (permalink)
View starfoxtien's Photo Gallery
i think its your throttle bearing. you might have put it in the wrong way so it make noises when your engine starts.
starfoxtien is offline   Reply With Quote
Old 09-28-2004, 09:35 PM   #3 (permalink)
oh a lot of people have that problem. i could be wrong thought but it's a good chance people usually put it in the wrong way.
Old 09-29-2004, 10:43 AM   #4 (permalink)
sounds odd
this was a dealer not saying they are perfect but you would think they would know what they are doing?
Old 09-29-2004, 10:44 AM   #5 (permalink)
put what in the wrong way
Old 09-29-2004, 12:07 PM   #6 (permalink)
people always put it in the wrong way because it looks like you can fit it both way from the back and the front. it'll work either way. just that it it's facing from the back than it makes a little clinging sound.
forget it if you don't understand.
Old 09-30-2004, 05:06 PM   #7 (permalink)
i just read your last post not the last two, there is only a chatter when it ingauges downshifting or start off.
Old 10-03-2004, 11:28 PM   #8 (permalink)
View Mr2Fixer's Photo Gallery
Two possibilities here:
(1) a Throw Out Bearing sticking. A TOB cannot be installed backwards, and still have a clutch that works.
(2) the input shaft bearing is going out. I had one go bad on me. It made a chattering sound especially when the clutch was not engaged and the transmission was in neutral.
I found out that Rockauto.com has input shaft bearings and clutch forks for Mk I's just the other day. And no Rockauto didn't pay me to say that.
Mr2Fixer is offline   Reply With Quote
Old 10-04-2004, 06:51 PM   #9 (permalink)
USA chatter
small noise when clutch pushed in, mostly first engaugement when starting off and down shifting, no slippage just chatter.
Old 10-08-2004, 06:25 AM   #10 (permalink)
View potfiend's Photo Gallery
in here is an extension i found for the slave cylinder, would that help?
http://www.speed-source.net/
and im about to do a tranny swap, you think i should get this if im upgrading to a light flywheel and cf dual friction clutch?
thanks
glen
potfiend is offline   Reply With Quote
Old 10-08-2004, 06:38 PM   #11 (permalink)
View MitchB's Photo Gallery
If your motor mounts are falling apart, they can cause SEVERE chatter.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
Old 11-14-2004, 07:58 PM   #12 (permalink)
dealer installed new clutch seems fine but I was thinking it might have something do do with temperature??, got cooler about the same time.
