Originally posted by socal 3SGTE
NoSirItsAToyota is it hard putting it back, should I know anything important before taking it apart. Thanks for the Idea
No its not hard at all. BOV's (especially the HKS) are very simple little things. I will say I'm not 100% sure that you can get it out from the inside, but I am 98% sure! There's a spring inside it and when you tighten that bolt, a plate moves up and compresses the spring more. So that bolt is right under the plate and I believe that plate comes off super easy (it might not even be attached to anything). Just give it a shot.
If only I still had that old SSQ here still I would check for you..
