check oil + battery lights
Just came on? Is there a common problem following/leading up to this? The car still starts fine, battery is fine, idle has not changed, do not overheat... did not run hard at all today. Not sure what could have caused this, was just cruising home and bam they turned on I do know that my cams are not aligned properly (can never get timing right, that will be adressed later on) I have 173k miles and have no idea whats going on? Oil changed about 1500 miles ago, am not low at all... any suggestions? Someone told me it might be my alternator, is there any way to test this my self?
