GReddy BCC install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2004, 09:18 AM   #1 (permalink)
View mr2trd's Photo Gallery
GReddy BCC install
has anyone installed one of these? Could i get some info on how to install this part...some pix would help too. thanks.
mr2trd is offline   Reply With Quote
Old 11-12-2004, 11:33 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The BCC completely eliminates fuel cut.
There is realyl no need to install it ... you can just cork the vac line to the OEM MAP sensor and fuel cut will be disabled.
The only reason to install the BCC is if you want the OEM boost gauge to still function ... but that gauge is worthless.
The HKS FCD raises fuel cut if that is something you would want.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-12-2004, 11:32 PM   #3 (permalink)
Will corking the vac line to the MAP sensor throw a CEL? So the GReddy BCC really has no benefits besides keeping the stock boost gauge functional.
Are there any risks of just corking the vac line?
thanks.
Old 11-13-2004, 05:03 AM   #4 (permalink)
I love Cin
Corking the vac line to the map will not throw a cell ... unplugging the electrical connection to the map WILL throw a cell.
The OEM MAP sensor does 2 things:
*controls fuel cut
*operates the OEM boost gauge
Unplug the vac line and you lose both of those.
Install the BCC and you just lose the FC.
Fuel cut is a safetey device to protect you from overboosting.
If you want to run more than 12 psi of boost, but you still want some protection the HKS FCD can RAISE FC to 17 psi.
If you want to run more than 17 psi, you have to eliminate FC.
I've been running for 3+ years with my MAP sensor corked.
Old 11-13-2004, 09:38 AM   #5 (permalink)
Thanks a lot J-n-H. You're always helpful in answering questions.
