smog pass
toyotas seem to run close to the edge during smog checks.my sugg. first. make sure the egr is functional. easy to check. with engine idleing in neutral. second. chage the oil (yep) lots of contaminants in there. third. run a full can of BG Brand fuel system cleaner through the tank. fourth. take it for the smog check and pay them to do a pre-test. (dont let them hook you up to the computer as yet..if you get tagged as a gross polluter you will get stuck going to a test only station for the rest of the cars life. also, take out the O2 sensor, examine it, is it carboned up? replace it. if its serviceable, the BG cleaner will really clean it up. Make damn sure you get the car nice and hot before you go for the testing. also, clean out the throttle body with some crc brand or similar throttle body cleaner.........
