need your suggestion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2004, 11:06 PM   #1 (permalink)
View gotriceboy05's Photo Gallery
Arrow need your suggestion
i just bought a stock 91turbo mr2. i wanted to know what are the first few performance parts you all look into buying for it.... thank you
gotriceboy05 is offline   Reply With Quote
Old 11-25-2004, 11:40 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
1st thing is to make sure everything is hunky dory ...such as cooling system, oiling system,ignition system, electrical systems. when you start modifying and putting stresses on your car, you want to make sure those components are functioning properly. then- intake(let your engine breathe more), intercooler, boost controller(u will need FCD) and exhaust system. you'll free up the hp/trq already there. I have a '91 also. I saw a significant increase in power just with the Electronic boost controller. just depends on how far you want to take it, how much time and money you're willing to spend and what your HP goals are. this forum is a gold mine of info. Dr. jeckyl/Hyde, MRQTurbo, Ishcoleobo have helped a bunch and are very knowledgeable on the MR2.
The Jedi Speeder at CarDomain
Old 11-26-2004, 05:49 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
As MR2BAd suggested, I would first do a healthy tune up.
Get yourself new TOYOTA cap, rotor wires and plugs.
Do an oil change and get some Castrol Syntec 10/30 in there.
Check out the coolant system.
I would do a fuel filter as well ... and an air filter, unless you are going to get a performamnce intake.
After you consider those items, read and learn a lot here:
http://www.mrcontrols.com/primers/power.htm
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-26-2004, 07:31 AM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
get some blue neons and spinners yo........
i'll second the recommendation to first to a basic tuneup.....change ignition components.....then get an FCD....a boost controller.....and a decent boost guage....exhaust/downpipe and an upgraded IC should be next.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 11-26-2004, 12:37 PM   #5 (permalink)
yah its getting a tune-up right now. what is a FCD? what about suspension,clutch,short shifter ect.... i thought those would be one of the first things?
im new at this soo sorry if it doesnt make sence
Old 11-26-2004, 12:40 PM   #6 (permalink)
I love Cin
FCD = Fuel Cut Defencer.
The computer limits your boost to 12 psi (by cutting fuel).
The FCD raises the FC point to 17 psi.
You can eliminate fuel cut completey for free though.
Clutch - No reason to buy one, unless yours is broke.
Short Shift - they are nice, but do not offer any huge advantage
Suspension - that is up to you. Upgrading the suspension can make the car handle significantly better.
Old 11-27-2004, 07:40 AM   #7 (permalink)
View borboyous's Photo Gallery
Sorry to hijack a thread, but, how do you upgrade the IC? Also being a noob I thought it was a fair question
borboyous is offline   Reply With Quote
Old 11-27-2004, 08:30 AM   #8 (permalink)
I love Cin
You can buy an upgraded intercooler kit (like the GReddy or Spearco) or you can get a better core and make your own kit (lots more work, but more afforadable ~ possibly).
Some people even do custom trunk-mount intercoolers or water-to-air intercoolers.
The possibilities are endless really.
Old 11-27-2004, 07:31 PM   #9 (permalink)
where do the IC usually mount at? i was a honda guy soo all this is kinda "reverse?" to me... i was thinkin about getting a good set of suspension first, does anyone know if custom exhaust piping/down pipe is any good or OKAY to have ?
and what websites have good aftermarket parts for mr2?(parts like the ones mention above)
Old 11-27-2004, 08:13 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
you might wanna just stick with Hondas... the basic principles are the same as with all forced induction engines. just different placement.
Old 11-28-2004, 07:44 AM   #11 (permalink)
I love Cin
gotriceboy05, most of the more common IC upgrades mount in the same location as factory. As I mentioned above, some custom set ups are mounted in the trunk ... some air-to-water setups are mounted above the engine.
As for getting parts, I would suggest clicking the image in my signature ... it will take you to ATS Racing. Talk to Aaron there, tell him I sent you You can help you with any of your build up needs.
Old 11-28-2004, 06:58 PM   #12 (permalink)
okay, ill check it out. thank you
