Squeeeeeeling belts !! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2004, 09:21 AM   #1 (permalink)
beaten by Fujiwara panda
nato1012's Avatar
View nato1012's Photo Gallery
USA Squeeeeeeling belts !!
I actually forgot to post this yesterday but, my car's belts squeel like there is no tomorrow. Im not so sure if it has anything to do with the AC belts having been removed due to compressor seizure or its the tension. I had it looked @ by my Toyota Tech friend and he said the belts were fine. I would have to warm up my car for 20 min to avoid the shrill. It is especially worse when it rains. there is also a faint squeel when Im at a Stand still and i am applying the brakes.
Any Ideas as to the Cause of this?
Thanks in advance
http://www.cardomain.com/memberpage/764918/2
NATO1012 New Jersey
MR2 Turbo Super white
nato1012 is offline   Reply With Quote
Old 12-07-2004, 05:21 PM   #2 (permalink)
VIP
View SILVERROLLA's Photo Gallery
I have the same prob on my 95 and you but not as worse. I get the squeel from time to time but only on start up and when it rains. I took it in for warranty work so they can check it out and the belts were changed and still I get the squeel with the new belts. Tension is fine and my A/C belt was also replaced under warranty. I have to go back and let them check it out again because I heard that I might need some bearing back there, thats why there is a squeeling noise but I will find out soon after I talk to my Toyota Tech
SILVERROLLA is offline   Reply With Quote
Old 12-07-2004, 09:39 PM   #3 (permalink)
old fart
View el niño's Photo Gallery
we used to have the same problem with the race cars, solution: put some valve grinding compund on the, not a whole lot, I know it sounds crazy but it worked for us.
does keeping your foot down count as forced induction?
el niño is offline   Reply With Quote
Old 12-08-2004, 11:07 AM   #4 (permalink)
nato1012's Avatar
Thanks for your input..by any chance where would I be able to get that valve grinding compound and where specifically must it be applied to? thnaks again
NATO1012 New Jersey
Old 12-08-2004, 11:29 AM   #5 (permalink)
old fart
any parts store would carry it, and I know, I finger fugded it, we put it on the belt itself.
