Checked the BGB... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2004, 04:51 PM   #1 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
Checked the BGB...
My 91 turbo stutters after 5500 rpm, as though it isn't getting enough fuel. i haven't replaced the fuel filter yet, and am going to soon. But i looked through the bgb and couldn't find how to replace it, and i was vague on the location. Any quick comments to help me find/change it? Thanks.
Strat42586 is offline   Reply With Quote
Old 12-22-2004, 05:28 PM   #2 (permalink)
derka derka
View fuelslut's Photo Gallery
i have none but i live in broken arrow just thought that was cool i was that close to you.
fuelslut is offline   Reply With Quote
Old 12-22-2004, 05:51 PM   #3 (permalink)
Gameroom cash: $253010
iTrader Score: 6 reviews
View BDSL's Photo Gallery
check your ignition components (spark plugs, wires, rotor, distributor cap)
BDSL is offline   Reply With Quote
Old 12-22-2004, 05:56 PM   #4 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
BDSL is dead on ... get yourself some new TOYOTA cap, rotor, wires and plugs.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 12-22-2004, 06:07 PM   #5 (permalink)
Thanks Coach!
Old 12-22-2004, 06:30 PM   #6 (permalink)
aka "Downforce"
Already have those replaced, alone with an APEXi power intake. That's why I turned to the fuel filter as the next thing to change.
Old 12-22-2004, 06:40 PM   #7 (permalink)
aka "Downforce"
By the way, that's along* with a power intake.
Old 12-22-2004, 07:30 PM   #8 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
do u have an exhaust leak??......common problem with 91 manifolds warping and causing a leak.....do u hear a ticking sound coming from the engine bay???.....can you hit full boost??.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 12-22-2004, 09:00 PM   #9 (permalink)
I love Cin
What plugs did you use and what gap?
... please don't say "Bosch Platinums"
Old 12-22-2004, 09:11 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
View MR2Jedi's Photo Gallery
I concure with MRQTurbo.. My '91 made the ticking noise he described.and it was a warped manifold. couldn't hit full boost and it would sputter on the high end like it was starving for fuel or air. My tech friend picked up on it right away. it was about $300.00 for new stock manifold
The Jedi Speeder at CarDomain
Old 12-23-2004, 02:48 PM   #11 (permalink)
aka "Downforce"
I just got the oil replaced after 1k rpm, and the gear oil changed. Seems to be pulling hard now. I took it to Toyota for the oil this time, instead of one of those quickie places. Spark plugs are NGK coppers at .028" gap. Everything else is Toyota. I don't have an aftermarket boost gauge yet, but the needle on the stock boost gauge will go past the "+" sign, so i assume it is boosting just fine. I heard about the manifold problem, and am hoping it's not that. I don't haven't noticed a ticking noise. I haven't really been listening for it, but I haven't noticed any noises out of the ordinary.
Old 12-23-2004, 02:57 PM   #12 (permalink)
I love Cin
What are your mods that you have such a narrow gap of .028" ?
Old 12-23-2004, 03:41 PM   #13 (permalink)
Check your intake plumbing and make sure there is no leak.
Check your ignition timing.
Old 12-23-2004, 03:42 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
if it was a wapred manifold you would here the noise. can't miss it.
Old 12-23-2004, 09:13 PM   #15 (permalink)
aka "Downforce"
I gapped the plugs so small because I have a boost controller, gauge and FCD waiting to be put on. According to the power primer, when boosting over stock it recommends .028 gap.
