MKII JDM fog lamp questions
I recently purchased the JDM fogs for MKII. As you may know they are directional fogs that turn with the steering wheel. At this point I do not wish to have them function w/ the wheel. I just like the green/yellow color of the light and want to have them serve as conventional fog lamps.
I am worried that they may not be centered. In other words, if the donor car did not have her steering wheel straight center then the fogs won't be that way either. Anyone know if they default to center position once the ignition is off?
Also, in the future I plan to make them function as intended but will need the ECU for them. My car has manual steering so there is no electrical whatsoever involved in it. You could say the car does not "know" where the steering is at any time. Were these JDM fogs only on cars with the electrohydro. steering or is there a transducer that converts mechanical movement into electrical siganls?
And finally, there is a 5 pin plug at the back of the fogs for the steering function. Does anyone know which pins are for what and which a hot 12 volt lead can be attached to in order to perhaps center the lamps if they do not do so by deafult once the ignition is off. Japanese owners of MKII would be a great help here.
