Strange fuel psi issue
Ok, here's one I've never seen before.
91 MR2 with 93 3sgte swap, Walbro 255lph pump, Supra injectors:
Running fine until all at once, instant rich problem. Checked all the basic normal causes such as leaky intercooler pipes, sensor connectors, etc. All is verified to be good. Checked fuel psi...80psi @ idle! Checked fuel psi DOWNSTREAM of the regulator (between regulator and pump)...80psi @ idle! I've never seen super high fuel psi AFTER the regulator before.
Pretty much has to be the pump, right? But what inside the pump could make this happen? Also, as soon as the car is shut off, the pump holds 0psi in the line, which tells me the check valve is crapped out for sure (if there is one on that pump-not too familiar with it).
Thanks for any info.
