Reversing problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2004, 07:12 AM   #1 (permalink)
View gman43ou's Photo Gallery
Unhappy Reversing problem?
Hello, my car dies when I try to shift into reverse. The rpm's will drop and the car will stall. Afterward, I have to pump the gas pedal a couple of times for it to start again. Can't start it in reverse either. Sometimes though, shifter will go in reverse and car acts normal. HELP!
gman43ou is offline   Reply With Quote
Old 12-29-2004, 07:21 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
most all cars you can start in reverse unless it's a manual, there a switch there so it wount. and any more info about your car? also check the fluid levels
^ and leaving it that way!
Old 01-01-2005, 07:07 PM   #3 (permalink)
Vehicle is a 92 non-turbo 5 speed. has about 80k mi and is otherwise in tip top condition. Car will start fine, but when I try to shift in reverse to back out of the driveway it will stall out. Sometimes what I have to do is rev the engine high, drop the shifter in reverse and let the clutch go. This gives me the momentum to back out, but it still dies.
