newbie front caliper question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2005, 08:30 AM   #1 (permalink)
View keck03's Photo Gallery
Hi I just bought a '92 NA. I noticed the front brake pads were low so I decided to replace them. I noticed the pads had worn uneven. There was almost no pad left at the bottoms. After I reassembled everything I noticed that both front wheels did not move freely to the point the car could stop by itself on a hill and remain stopped. After further examination I noticed that on both sides the bottom caliper pin did not slide at all. Even a rubber mallet wasnt enough to persude it to move like the top pins. The wheels didnt lock up though after the tapping. Since it was my first time with the brakes, my question is this. The bottom pin should move right? The caliper should be able to "float" with the rotor right? I was looking for some input before I drop it off at the brake shop. Thanks in advance.
keck03 is offline   Reply With Quote
Old 01-10-2005, 10:53 AM   #2 (permalink)
Gameroom cash: $253010
iTrader Score: 6 reviews
View BDSL's Photo Gallery
You should be able to move the caliper freely. Your caliper is sized. Next time you do your brake, make sure you clean and lub the slide pins.
BDSL is offline   Reply With Quote
Old 01-10-2005, 11:10 AM   #3 (permalink)
thanks for the info. thats pretty much what i had thought. i just wanted to make sure first. i had lubed the top ones (pins and bolts) but the bottom ones were stuck (why i tried taping them). thanks again.
Old 01-10-2005, 03:02 PM   #4 (permalink)
Both pins needed to be cleaned. Get a wire brush and clean the pins. The holes are harder to clean. I just pour some gasoline onto a small piece of cloth. On the bottom pin, insert the cloth at one end and out the other...do it a few times until the inside is clean. On the top pin, just use the cloth again but use something to poke it around. That should get both pins and holes cleaned.
Old 01-10-2005, 03:27 PM   #5 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
You can get caliper rebuild kits from Toyota for $20 for the front.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 01-11-2005, 03:48 PM   #6 (permalink)
thanks for the suggestions. i had contacted the dealership and they had the rubber rebuild kits for like $30 (does both), bolts for $1.50, and slides for $12. i really happy i dont have to buy the whole caliper. thanks again.
