mr2 3s-gte engine number - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2005, 10:46 PM   #1 (permalink)
Wazzuup!
MR2crazybyong's Avatar
View MR2crazybyong's Photo Gallery
guys,
i need your help. i need to find the engine number of my mr2 3s-gte .. where is it located? tnx so much..
MR2crazybyong is offline   Reply With Quote
Old 01-13-2005, 08:27 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
would that not be the same as the VIN number??.......check on the driver's side door...should be a label there from the factory......
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 01-13-2005, 09:44 AM   #3 (permalink)
Wazzuup!
no, im looking for the serial number of the engine block.. do you know where that is?
Old 01-13-2005, 11:32 AM   #4 (permalink)
usually its stamped on the block itself.....is the motor pulled or still in the car??...
91 mr2..07 335i..
Old 01-13-2005, 05:09 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Mine is on the side of the block on the rear towards the back of the car . I could see it when it was on the lift. but it is a new long block..
The Jedi Speeder at CarDomain
Old 01-13-2005, 10:17 PM   #6 (permalink)
Wazzuup!
the engine is still on the car, anyway i found it already.. its located under the thermostat.. what a place to put it... tnx guys..
Old 01-16-2005, 04:34 AM   #7 (permalink)
SPEC PIMP!!
View mister3's Photo Gallery
on USDM and canadian MR2s there is also a ID tag on the lower portion of the block and trans with the serial # -- JDM engine or trans do not have these ID tags
mister3 is offline   Reply With Quote
