turbo 5sfe crankshaft - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2005, 08:29 PM   #1 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
Question turbo 5sfe crankshaft
I've got a pretty simple question: Are there any crankshafts out there that would be able to hold up to the stress of a boosted 5sfe? I'm kind of worried about using a stock 5sfe crank with all of my other drop forged and hardened components.... I just thought it might become the weak point in my engine after all is said and done.
any input is appreciated,
thanks
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 01-19-2005, 04:37 AM   #2 (permalink)
View 91MR2quickNA's Photo Gallery
The stock crank is definitely not a weak point. You've covered the weak points if you've got forged pistons, rods, and a metal head gasket from 1997+ Camrys. Now if you have bad bearings in your crankshaft, then you'll eventually spin a bearing or experience crank knock.
The stock crank is used in 5S-GTE motors, some of which have produced more than 500rwhp. And also on 5S-FTE motors that have produced more than 400rwhp. Most of them have built bottom ends that are fully balanced and blueprinted, but still the crank is still a 5S crank.
Good info: http://www.mr2oc.com/showthread.php?t=4296
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 01-19-2005, 09:13 AM   #3 (permalink)
Gameroom cash: $147537
The 5S crank got bigger bearing then the 3S. Another reason why it can't rev high but able to give great torque.
Old 01-19-2005, 08:34 PM   #4 (permalink)
no more V-6...
amazing! thanks for your help..... one last question though: I have an extra crank that apparently had bad bearings, because there is some wear from the crank contacting the piston... now the question is... am I still able to use this crank? should I get it ground smooth? or would I be better off just getting a new one? I'm thinking I should buy a new one... just because I know it's not had the best life.... I've found new cranks for around $250.... I just want everything to be assured when I get this thing together...
thanks again
back to the 4cyl...
Old 01-20-2005, 10:58 AM   #5 (permalink)
Depends how much you have to grind down the bearing and how much it'll cost. If you have to grind too much, you can't find a bearing for the crank. If the damage is not on bearing surface, it should be fine, just sommth it out little bit. Too much and the crank lose balance.
Old 01-20-2005, 09:31 PM   #6 (permalink)
no more V-6...
I will take some pictures of the damaged crank in the next couple of days, I will post them to see what everyone thinks..... but from what pineapple is saying, I think I might be able to simply smooth out the rought spots... but I'll wait to see what the experts diagnose from the pictures.....
back to the 4cyl...
