CT26 Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2005, 10:30 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
CT26 Question
I have a CT26 that has a different compressor wheel. 6 blades instead of 5. anybody familiar with this set up? max psi output? spool up? etc...
The Jedi Speeder at CarDomain
Old 01-20-2005, 10:45 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
I would not go over 15 psi with the CT26, regardless of what the wheels have been upgraded to.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 01-20-2005, 11:00 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
do you see or know of any benefits from the upgraded compressor wheel?
Old 01-20-2005, 11:38 AM   #4 (permalink)
I love Cin
My understanding is that it should allow you to run more boost higher into the RPM band. Instead of the stock configuration that falls off. I suspect it may be more beneficial to have an upgraded turbine than an upgraded compressor.
I am hypothesizing, so I could be completely wrong.
Old 01-20-2005, 03:05 PM   #5 (permalink)
View WhiteMR291's Photo Gallery
HEy just a quick question, how come i see mk3 supra owners with 60-1 trim ct26's running 24psi?? I know that the turbo itself is actually bigger but not by much.
-Terry
WhiteMR291 is offline   Reply With Quote
Old 01-20-2005, 03:23 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
DR. J, I did more research since this post and found MR Controls 3s-GTE Power Primer suggests just that about the turbine side. They suggest a 15degree clip to help exhaust flow , but at the sacrifice of a later spool up.but you were dead on about the compressor side.. I'll let you guys know how this turns out...thanks
