Boost creep occurs when you are flowing more exhaust than the WG can handle.
The LOWER the boost pressure you are running, the more the WG needs to evacuate.
That being said, if your WG is insufficiently sized for the amount of boost you are trying to run, you can see/expect boost creep regardless if it is an internal or external WG. An external is less likely to creep.
The problem most people have with the TD06 is they try to run 14-15 psi on it which requires more of the exhaust to go through it's internal WG and it gets overwhelmed. The excess exhaust goes through the turbine producing more boost (hence creeping).
If people would just set the car up to run 18-22 psi, they would be less likely to creep
