it can be done with the engine in the car... just a really tight fit. I had to change my timing belt in an elemetary parking lot when it decided to go kamikazi one afternoon... but changing the belt wasn't the hardest part.... getting that fool back in time while it's still in the engine bay... I had to use two little mirrors..(GF's makup) to bounce the timing light around to the mark.... truly fun stuff.... but the cam gears should be no problem to remove. and if I can remember correctly it will be alot easier if you remove the passenger motor mount, and the engine hoist hook on the passenger side as well... them take a 10mm and remove the number 1 timing belt cover, loosen the idler pully ...12mm I think ... remove the upper portion of the timing belt, and have at those cam gears.
back to the 4cyl...
