very low idle rpms! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2005, 10:22 AM   #1 (permalink)
Wazzuup!
MR2crazybyong's Avatar
View MR2crazybyong's Photo Gallery
very low idle rpms!
guys, i need your help... my engine's idleing gets so low, like 500 rpm, sometimes even lower.. why is this? how can i fix this? appreciate your replys
MR2crazybyong is offline   Reply With Quote
Old 01-31-2005, 11:10 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Which engine do you have?
It could be a lot things ... clooged fuel filter/injector, vac leak in the intake, idle needs to be adjusted, lots of stuff.
If you have a turbo MR2 with an aftermarket BOV, I would look there first.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 01-31-2005, 11:42 AM   #3 (permalink)
Wazzuup!
opps sori.. i have the jdm 3sgte.. yes i hav an aftermarket BOV vented to the atmosphere but this didnt happen before, even with the open BOV.. maybe il try cleaning the injectors.. i had a problem before, the engine would just die down like i runs out of gas. the problem was a faulty wirring of the fuel pump, then after few weeks, this comes up..
Old 01-31-2005, 02:03 PM   #4 (permalink)
I love Cin
Make sure the BOV is not stuck open at idle ... even just a little bit.
The AFM has 2 little screws on the side of it. You never touched those did you?
Old 01-31-2005, 10:54 PM   #5 (permalink)
Wazzuup!
ok, il check the BOV.. no i havnt touched the screws.. maybe il need to clean the AFM, its so dusty.. hey tnx bro.. il update...
Old 02-01-2005, 05:48 AM   #6 (permalink)
I love Cin
I would not bother cleaning the AFM. If you do, be very careful and do NOT touch those little screws!
How old is your air filter? Maybe the engine can't breathe?
How old is your ignition? (cap, rotor, wires and plugs)? There is a date painted on the wires ... what is it?
Old 02-01-2005, 12:57 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I never noticed there was a date on the plug wires. what is the life expectancy of them?
The Jedi Speeder at CarDomain
Old 02-01-2005, 01:07 PM   #8 (permalink)
I love Cin
I replace my cap, rotor and wires once a year.
Some people say that is obessive.
I say I know my ignition is fresh.
Turbo MR2s with worn ignition components have been dynoed to be down as much as 35 rwhp!
The ignition pieces will last longer than a year. It really depends on your driving and your power level. I just do it to be safe.
Old 02-01-2005, 01:14 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
yeah , the toyota parts guys always give me a hard time when I ask for cap and rotor.."why do you need that? they last forever".. sorry but I can see a little pitting on the pick ups and end of rotor. so I change them...
Old 02-01-2005, 03:28 PM   #10 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
i'm with J&H too....change my cap and rotor every spring....plugs too....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-05-2005, 06:22 AM   #11 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
J&H.... um.... I totally removed those two little screws on my AFM...
only kidding... I had say something...just because how you stressed it in your post...
would you just throw the sensor out-of-wack if you did?
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 02-05-2005, 08:16 PM   #12 (permalink)
View blazin_azn's Photo Gallery
rpm idle
i have a different problem..my rpm needle idles at 1500..................
how do i fix it? wat should it idle at after it warms up with a N/A engine
blazin_azn is offline   Reply With Quote
Old 02-05-2005, 08:27 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
if manual trans, about 800rpm... check your timing
Old 02-05-2005, 08:54 PM   #14 (permalink)
u mean my timing belt?
Old 02-05-2005, 09:00 PM   #15 (permalink)
View MIGHTY's Photo Gallery
adjust the intake screw on the map sensor and the one on the throttle body....
MIGHTY is offline   Reply With Quote
