mr2 axles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2005, 02:58 PM   #1 (permalink)
View TOYSONLY's Photo Gallery
Canada mr2 axles
Help – we need axles for a 94 MR2 with a j-spec 3sgte with LSD. We need the center shaft and brearings and the two outer CV shafts. Searching in Canada.
TOYSONLY is offline   Reply With Quote
Old 02-07-2005, 04:15 PM   #2 (permalink)
yo soy "EL CUCUY"
CUCUY's Avatar
View CUCUY's Photo Gallery
welcome to TN, but you posted in wrong section..
CUCUY is offline   Reply With Quote
Old 02-07-2005, 05:15 PM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
good luck trying to source those in canada.....we never got any 94s here at all so used parts are next to nothing here.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-07-2005, 07:20 PM   #4 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
If you already have 3SGTE non-LSD axles, then all you need is the inner stubs from the LSD axles. You do not need the whole axle.
As for CV joints, if you are planning on making power with this car, I would suggest getting the ATS Racing chromoly CV joints. Click my siggy photo to go the ATS site ... tell them I sent you
Toyota Part numbers for the LSD stuff (prices are at least 2 years old):
Inner Axle Stubs:
D-side inner stub for LSD: 41309-17040 $126.77
P-side inner stub for LSD: 43049-17010 $259.28
Entire LSD Axle:
D-side: 42340-17171 $277.57
P-side: 42330-17211 $334.00
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 02-07-2005, 07:32 PM   #5 (permalink)
Canada Help J-spec 3sgte ecu pin outs
I'm currently installing a j-spec 3sgte motor in my stepson 93 MR2 which was a N/A 2.2. The motor is a 94. The 2.2 ecu chassis harness only had 12 pins but the 2.0 turbo has 22 pins. The Canadian toyota manual shows 22 pins but only 14 are used. The chassis harness from the j-spec ecu has all 22 wires coming from it. What are rest of these for?
The pin outs are as follows -
STA(pin 11 - wire color = red/silver stripe),
ABS(pin 20 - green/silver stripe), ABS system somewere?
ATS(pin 8 - blue/yellow stripe with twin silver bands) A/C amp?
CF(pin 19 - black/ silver stripe)
ABV(pin 18 - black/with twin silver bands)
ECO(pin 6 - white/silver stripe) this is Exhaust temperature sensor signal from after CAT.
STP(pin 4 green/white stripe with single silver band) this goes to stop light switch somewere
EGW(pin 3 red/with twin silver bands) - this pin is Exhaust Gas Warning to led in dash -not req.
Old 02-07-2005, 08:04 PM   #6 (permalink)
Inner Axle Stubs:
Entire LSD Axle:
No we only have 5sfe axles. The prices i got from Toyota Canada are about the same converted to cnd$$. I'l try the ATS site because we do plan to make power eventually but just want to get er ready for the spring for now.
Old 02-07-2005, 08:04 PM   #7 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
You don't have the wiring harness from the 3rd gen?
Old 02-07-2005, 08:11 PM   #8 (permalink)
We have the engine harness and about 16" the chassis harenss from the ECU. The engine is running with any engine codes but since I don't have axles yet I can't test drive it to see if any other problems show up.
Old 02-07-2005, 08:14 PM   #9 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Do you have the diagrams? If not let me know, I'll hook you up.
STA goes to either the C/OPN relay or the EFI relay
ABS probably goes to the ABS computer
ATS goes to the a/c amp
CF goes to fan #1 relay
ABV no idea
the last three you already have figured out, right?
Dr Tweak is offline   Reply With Quote
Old 02-07-2005, 08:25 PM   #10 (permalink)
ABV no idea
Thanks JD i have the Canadian/US diagrams but not the japanese ones - oh yeah the diagrams i do have are for a 93 the engine is a 94? If you the jap diagrams that would be great.
Old 02-07-2005, 08:27 PM   #11 (permalink)
The Mad Scientist
So, you have the US diagrams for the 3SGTE and those wires on not on there? I'm not talking just the pins, did you search out the diagram to see if they are in there?
BTW, I've been told you can just use an LED for the exhaust temp warning light... haven't tried it yet though.
Old 02-09-2005, 11:54 AM   #12 (permalink)
Canada j-spec ecu pinouts
I'll have to look closer at the chassis wiring drawings but the pinouts on the ecu drawing are not the same. I opened the j-spec ecu to identify each pin. The north american ecu i have is from a 2.2 N/A which only has 12 pins.
