Rear Left QP in need of TLC - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2005, 07:49 PM   #1 (permalink)
View jonrat's Photo Gallery
any ideas as to how I would go about fixing this? ( without changing the entire quarter panel) Much thanks
http://ca.msnusers.com/_Secure/0RQAl...09195628665836
Last edited by jonrat; 02-07-2005 at 07:53 PM. Reason: picture still not showing up...
jonrat is offline   Reply With Quote
Old 02-07-2005, 08:38 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
lots of bondo......i think u will need a replacement 1/4 panel.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-08-2005, 05:37 AM   #3 (permalink)
View vtsuckah's Photo Gallery
oh geeze, the rust is a bit too bad at this point. You can even notice the discoloration around the fender flare as well. Might as well get a new quarter panel, or else your "quick fix" will only be a waste of time and money. Or you could cut the rusted section off, find a fender from another mki, cut off a matching section, and weld on the new, then you would need bondo, paint, etc. For all that trouble, might as well replace the entire thing. Salt is the devil....sorry bro.
vtsuckah is offline   Reply With Quote
Old 02-08-2005, 07:59 AM   #4 (permalink)
The discolouration is some red rust paint that the previous owner had on the car...The kid who had it before decided against rust proofing and drove the car often in our wonderful canadian winter... I came across this: http://www.mr2-solutions.com/rear_overarch_kits.html , do you think this might work? Also, I plan on storing her in winter, so salt won't get a chance... if i do have to change the quarter panel, do you think i'd be able to get one used, i.e off someone's car? How much does that usually cost... thanks a bunch
Old 02-08-2005, 08:19 AM   #5 (permalink)
No, it won't adhere if the fender continues to rust. Yes you can find a used quarter panel in a junk yard. Price depends soley on the particular junkyard. Look around at diff junkyards for a better price. good luck.
Old 02-08-2005, 05:46 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
sorry,but like MRQ said, you'll either have to replace the quarter panel or tons of bondo. The only other option I can think of is to cut both side fender flares and make(or buy) new wider flares that look cool...
The Jedi Speeder at CarDomain
Old 02-08-2005, 06:32 PM   #7 (permalink)
yeah, my cousin suggested cutting all four fenders off and either weld or pop-rivet fenders from a car with wider fenders (like a celica supra or sthing)...is that feasible?
Old 02-08-2005, 08:31 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
yeah, if the curvature is correct. they sell fender flares that can be put on the same way or you can make some from fiberglass. why do the front though?
Old 02-08-2005, 09:30 PM   #9 (permalink)
well...i figured to keep the flares even... but having only the back ones might look even better..thanks man..
Old 02-08-2005, 09:33 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
you may not even have to cut depending on the flares. just get rid of any rust and seal it. then maybe the flares will hide the old stuff... good luck. hey, post pics when ur done
Old 02-09-2005, 10:51 AM   #11 (permalink)
why are u againest replacing the entire q/p??....are u looking for the cheapest alternative to fixing this problem??....if u plan on keeping the car for another few years....spend the money now to STOP the rust from spreading and fixing it properly....if not...don't bother spending money on it and just let rust away.....
91 mr2..07 335i..
Old 02-10-2005, 05:40 AM   #12 (permalink)
I totally agree with Q. If you do something like that, fix it right instead of half arsing it.
Old 02-11-2005, 09:01 AM   #13 (permalink)
well...that is why i posted on here, alot of good advice now i need to take it to a shop have them check it out...
Old 02-13-2005, 03:23 AM   #14 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
AMPUTATE!!!! before that cancer spreads.
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
