throttle body removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2005, 05:39 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Got '91 MR2 Turbo. I want to remove the throttle body so I can put on my new valve cover.It looks like there is a metal gasket between throttle body and intake manifold. Is it reusable or will I have to get a new one for reassembly?thanx
The Jedi Speeder at CarDomain
Old 02-15-2005, 01:02 AM   #2 (permalink)
Gameroom cash: $147537
You can resue it if it doesn't crack when you remove the TB. Most likely new one from Toyota is metal. I got all metal gasket form Toyota with my 5S-FE kit.
Old 02-15-2005, 09:45 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
thanks. i was hoping that was the case. I was able to use the metal gasket over again from the throttle body inlet. BTW-Pineapple?
Old 02-15-2005, 10:00 AM   #4 (permalink)
As long as you don't scratch the metal gasket, you can reuse them forever. Of course a bit of silicone never hurt. I don't think the engine will leak again with all those metal gaskets
Try to confirm with other to make sure its metal gasket when you order. I just ordered 5S-FE rebuild kit and it come with metal gasket. Don't know if it gonna be the same for 3S-GTE.
Old 02-15-2005, 08:57 PM   #5 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
pineapple.... where did you order your gasket kit from?
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 02-22-2005, 06:25 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
hey, the gasket was still good.. thanx guys
