antenna help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2005, 04:09 PM   #1 (permalink)
View vtsuckah's Photo Gallery
antenna help
I bought a replacement antenna mast on ebay. The directions tell of a nut that acts as a stop for when the antenna goes all the way up. It says to losen it.
where is this nut and how do i losen it?
here's the directions that it has given me
http://www.antennamastsrus.com/Instructions.htm
vtsuckah is offline   Reply With Quote
Old 02-15-2005, 05:26 PM   #2 (permalink)
I found directions from http://www.mr2.com/TEXT/InstallAntenna.html. Is there any other way to install this damn thing without taking off the side of my spoiler? The bolts are very hard to access.
Boy has this been a headache. mr2: 1, me:0
Old 02-17-2005, 09:31 AM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
can't u access it from within the trunk??...do u still have the carpet liner there...i don't have mine and to me it seems like i can see all antenna parts/shaft/motor....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-17-2005, 09:47 AM   #4 (permalink)
I took out the carpet liner. Yes you can see the shaft/motor, but the nut that is to be loosened can't be reached. I believe it's above the black rubber thingy. Not sure though.
Old 02-18-2005, 07:17 AM   #5 (permalink)
View carcatz's Photo Gallery
it bolts to the body and they added an extension to reach the spoiler,you've got to remove the spoiler two nuts not that hard to reach. On mine there are two nuts in the rear and a type of push clip in the front I just pried it straight up. 91 turbo
carcatz is offline   Reply With Quote
Old 02-18-2005, 07:41 AM   #6 (permalink)
The clip that you're talkin about......which way is front? the Trunk or towards the engine bay? I didn't see a clip when I was rumaging down there.
Old 02-18-2005, 12:37 PM   #7 (permalink)
if it is 91 style wing the clip is at the tip of the spoiler toward the front of the car, you can't reach it from the inside. after you remove the 2 nuts it will still feel attached they are kind of stuck pretty well, I had to put some force on it to get it to move. the back should loosen you should be able to work the front clip loose. this is just how I did it and caused no damage on mine. good luck
Old 02-18-2005, 01:01 PM   #8 (permalink)
When you remove the spoiler and put it back on, what prevents water from leaking into the trunk? I'm concerned b/c when i had my 2 repainted, I believe the body shop used some sort of adhesive to prevent leaks
By the way, thanks for everone's help.
Old 02-18-2005, 02:18 PM   #9 (permalink)
yeah I resealed mine around the stud hole to but they do stick anyway if they haven't been painted.
