All four cylinders dont run..? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2005, 04:14 PM   #1 (permalink)
mcandrewsr's Avatar
View mcandrewsr's Photo Gallery
Canada All four cylinders dont run..?
Any pointers?
I'm thinking new distributor cab and rotor/spark plugs.
Any other ideas?
-1991 MR2 Turbo
-2003 Tacoma 4x4 (Sold)
-1994 Supra Twin Turbo
mcandrewsr is offline   Reply With Quote
Old 02-15-2005, 08:10 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
is the cam turning?
Old 02-15-2005, 08:40 PM   #3 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
can the engine turn over? if it seems to turn over a little faster than before the problem started, your timing belt might have slipped off or broke....
if it turns over fine.... have a friend (not a good friend) hold one of the spark plug wires with the plug still in it against a good ground... turn the engine over, and see if it arks... if so try each wire ... if they all work----- then it's not your timing belt or your distributor\rotor\wires....
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 02-15-2005, 10:42 PM   #4 (permalink)
mcandrewsr's Avatar
got it working
I ended up taking out the spark plug for cylinder #2, and I noticed wet fuel sitting above the cylinder. So I figured the sparkplug wasn't igniting. So I unplugged the fuel injector for #2, start it up to get the wet fuel out of there. Afterwards I plugged the fuel injector back in. And now it's running great.
-1991 MR2 Turbo
